Shane
Help in deciding whether or not to install v3
- kevinshane
- Contact:
I am still between the very old octane1.2a and octane2.23.2-1.9 version
Lucky for that 1.9 got everything I need to work arch-viz
Shane
Shane
Hey Coilbook..
I haven't had the chance to change yet..finishing an animation and still on 1.9, dont want to mess things up during production
but MOST likely when i do i will choose to redo (ouch) all the necessary material and don't just rely on conversion scripts...especially for things like mix mats
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
nildoe wrote:Hey Coilbook..
I haven't had the chance to change yet..finishing an animation and still on 1.9, dont want to mess things up during production.
Ok Thanks. Same here trying to finish the project before moving on to a new one where I will use 3.0
You need to try open the old scenes at least in plugin 2.23 or 3.17. They have some workarounds implemented to eliminate this as much as possible.coilbook wrote:... 3ds Max crashes if you use newer renderer mostly because of old mix material.
hi Jimstar this one with mix material crashes max v2.23.2 - 2.0 or aboveJimStar wrote:If you have some scene that still crashes in these versions - you can share it with me and I will check what can be done...
- Attachments
- new octane crash2.zip
- (6.2 MiB) Downloaded 150 times
I'm sorry, but have you read what I wrote in previous post?..coilbook wrote:hi Jimstar this one with mix material crashes max v2.23.2 - 2.0 or above
These mentioned are the plugin versions, not the Octane core versions (please read the version number description placed on the top of each release topic). You are trying to open it in 2.0 version. No surprise it crashes there.JimStar wrote:You need to try open the old scenes at least in plugin 2.23 or 3.17
JimStar wrote:Here are the versions you need:
v2: viewtopic.php?f=80&t=54453
v3: viewtopic.php?f=80&t=54866
ok will try Thank you
