Unable to project Gradient through camera
cashley
Also, is there currently any way to limit a shaders reflection from seeing an HDRI Env Light?
check this for two possible options.
test.rar
(598.63 KiB) Downloaded 142 times
cashley
Thank you very much for putting this together! Is there any way to use a gradient instead of a texture map as the background image?
cashley wrote:Thank you very much for putting this together! Is there any way to use a gradient instead of a texture map as the background image?
As i said that's very rough to set. Because gradient is not generator and need a incoming connection from a sinewave texture. Connect a projection and transform to sinewave.
