Unable to project Gradient through camera
check this for two possible options.
- test.rar
- (598.63 KiB) Downloaded 147 times
As i said that's very rough to set. Because gradient is not generator and need a incoming connection from a sinewave texture. Connect a projection and transform to sinewave.cashley wrote:Thank you very much for putting this together! Is there any way to use a gradient instead of a texture map as the background image?
