Create random textures over instances
Forum for OctaneRender Lua scripting examples, discussion and support.
Yugs
Thank you very much for this!
Also, is there a way to have such scripts saved in the toolbar instead of having to reload it through the editor?
Cheers!
stratified
Yugs wrote:Thank you very much for this!
Cheers!
You can configure a scrip directory (via File -> Preferences -> Application tab). All the scripts in this directory will have an entry in the script menu (Only after you clicked "Reload user scripts" in the script menu).
cheers,
Thomas
oguzbir
This is perfectly great.
But what about the plugin users.
this has to be implemented in core. and make use of it in 3dsmax and others
Don't you think?
My Portfolio
smicha
oguzbir wrote:This is perfectly great.
Don't you think?
I am using this in Modo via standalone node import function.
fabrizio_s
I'm trying to use this script in rhino plugin but it doesn't work.
Is it a simple way to fix it? It would be very very useful
thanx
fabrizio
Hi fabrizio,
you have to export your scene to Standalone and use the lua script there, I guess.
fabrizio_s
Hi Beppe,
yes, this is the final solution...But I'd like to work into the plugin...Is there a simple solution?
ciao
Rik
This seems great but how do we use it in max?
No idea what lua is.
Have the standalone but never use it.
franchais
would be good to have this implemented into rhino or 3dsmax plugins
I7 2600k | EVGA gtx 680 FTW 4gb | Win 7 x64 | 16gb RAM
smicha
Huge wish to OTOY - please code it into Octane nodes, not LUA.
Return to “Lua Scripting”
