render with animated image sequence dont work
Paul excuse me but I followed your instructions but without a positive result, please send me the old version of plugin 2.22.2.42 and i try it ...
There was no 32 bit build of 2.24.2.42.
I think we will spend a lot of time trying to sort this out - when it would be much easier for you to upgrade to 64bit Poser.
Andygraph3D
I found my error !
the sequence is visible only if i start the render from 1 frame
when i try to render to next frame the plugin always render the first frame then from 2 render onwards begins the sequence so I did not understand because it is from any starting frame render always I saw the first frame :-P
maybe write it on the plugin manual would not be a bad idea .. ;-)
Return to “Poser”
