Version 2.24.2-R2 (22.01.2016)
rodross
I'm getting a ton of freezes on material changes and dragging and dropping. Actually have had to kill the C4D process 4 times in 2 hours. As well the LV doesn't seem to be updating on changes as well as Test5 did. Reverting back from stable to Test5 if changing to the r17 file in the plugin folder doesn't fix it.
Edit: How do I get Test5.2 back?
rodross wrote:I'm getting a ton of freezes on material changes and dragging and dropping. Actually have had to kill the C4D process 4 times in 2 hours. As well the LV doesn't seem to be updating on changes as well as Test5 did. Reverting back from stable to Test5 if changing to the r17 file in the plugin folder doesn't fix it.
There is not differences as you said between two versions? What's your C4D version? What kind of scenes are you talking?
I have disabled download links until investigate more the current version.
fuchsundvogel
when i apply the randomeffector to the scatter object. i get a crash after some seconds.
should be reproducible. just open the file, start LV and drop the random effector in effectors tab.
testfile_stableversion.zip
(62.62 KiB) Downloaded 378 times
fuchsundvogel wrote:when i apply the randomeffector to the scatter object. i get a crash after some seconds.
pxlntwrk
c4d freese randomly( frame 93 , frame 133 etc..), during anim render, this afternoon impossible to render 300 frames straight. :(
pxlntwrk.net
pxlntwrk wrote:Hi,
Do you think these helps? Just giving more anxiety.
Please post more details as i described in release post. Scene, bugreport, etc..
pxlntwrk
yep, i know that :? and i'm sorry
but c4d freese = nobugReport at all
for scene, i have to debrand before send it , and before and before i had to render my job...
pxlntwrk.net
fuchsundvogel
win7 / R17.048
the LV update is slow when i activate octane scatter. also when the cloneamount is only 1.
LV.mp4
(5.66 MiB) Downloaded 5684 times
testfile_stableversion02.zip
(72 KiB) Downloaded 363 times
pxlntwrk wrote:yep, i know that :? and i'm sorry
It's very hard to help when lot of people flood many post. Please send me a scene to test it. Also describe the steps to reproduce. I cannot simulate every scenario to avoid problems/crashes. C4D is very big tool and imposible to test every functions without your helps.
