Peter,
Those are the exact steps I followed to modify the kexts. And on my MBA, I do still see the IONDRVSupport.kext so I'm not sure why yours has gone missing?
One last thing I did do was run Kext Utility, which I read somewhere would help set the permissions on the modified kexts correctly. I got mine here:
http://cvad-mac.narod.ru/index/0-4
I'm not using Nvidia drivers so I can't confirm if there's any issue, since my 780 seems to be supported by El Cap native drivers.
I don't really have a cheatsheet, but I've been casually documenting the steps ever since I started doing this from Mavericks, hope the attachment offers some help.
andrew
Does anyone have external GPU/thunderbolt in Os X El Capitan
- mustardseedsg
- Contact:
- Attachments
- How To Edit Kext Files For Thunderbolt eGPU.rtfd.zip
- (129.26 KiB) Downloaded 256 times
Mac OSX 10.12.6 / MBP 15" w Touch Bar, 16GB / Mantiz Venus Thunderbolt 3 enclosure with GX1080 / C4d r19 Octane
- p3taoctane
Very Thourough.
Thanks I'll try them as there a a couple of steps I did not do.
How would you feel about zipping your ONDRVSupport.kext and sending it to me.. I have no idea why I do not have one and I hesitate to use my yosemite version.
You help is much Appreciated
Peter
Peter
- p3taoctane
Thanks your tips helped
I see the Nvidia PCE cards in the About this Mac graphics display but they are not recognized as the make i.e. Titan.
I had installed the nvidia and web drivers and cuda El Cap is supposed to support... did you instal any drivers or cuda files??
Or did El cap just take care of it?
I am going to uninstall them and try that.
Thanks gain for any insights
Peter
I did find that ONDRV file.. my bad
Peter
- p3taoctane
Anyone out there know what I might have done wrong
I am on El Cap and and a MacBook Air
I am connected to a Titan Z and a Titan
In My :About My Mac: System information: Graphics/Displays Tab I see
NVIDIA Chip Model GPU PCI
(Two x's from the Z and one x)
But it does not recognize what kind of card it it. Because I am on El Cap I did not instal the Web driver just the Cuda Driver.
One other piece of info... the System/Library/Extensions/ XXX.kext files that one shows package contents and edits the info.plist files in text wrangler shows todays date as the altered date.... good.... but actual NVDAStartup.kext files (as an example) shows an older date... I am guessing a creation date.
I ran Kext Utility file to make sure the kext files were apple certified etc and I see a normal kext file and a fdr called by the same name says AppleHDA.kext.bak that I looks like it is a backup of the old original file. It's appropriate info.plist file has an older date.
I am running rootless. I reboot after each change .
ANY IDEAS APPRECIATED
Ghm, some Guys managed to run multiple GPUs with new OS, but failed runiny different SKUs..for the sake to prove this & see if that helps..take of Your TitanZ or Xs out Your Mac =) You might try to solve unsolvable problem..
- p3taoctane
That was my next step mate.
I have had both types running under Yosemite and I tried Two Z's with this effort and not go so it might be that El Cap does not like Z's.
Will try just the Titan and see if that works.
Darn frustrating... Mac OSx has a lot of good things ... the fact that it is such a dick when it comes to nvidia collaboration is way beyond me man.
Thanks as always Glimpse.
Hope all is well with ya.
Peter
Peter
- p3taoctane
Well that did it Glimpse.
Unhooked the Z and it worked....
Anyone running TitanZ's on Mac OSX with e GPU
I think its the new drivers. El Cap has its own Nvidia drivers and if you use those the Z does not show up.
The reason why I think is this is the case is that I upgraded to the latest drivers on my Yosemite machine and the Z stopped it running too.
Thinking that I either have to go back to the old drivers...
Anyone running Z's care to let me know whih driver they are running???
ghm..look through this search box & under the "mac + eGPU" think I saw Guys running Zs over there =) You should find some hints over there.p3taoctane wrote:Well that did it Glimpse.
- Allan_onderick
I have that script link above working. it automates everything you need to do. My 780 ti runs great. Im trying out a 970 SC tonight.
Windows Rig: Win 10 64, 64gb , 256 SSD, Stable OC i7 4.7Ghz Corsair water cooled, 1200 watt PSU, 3x MSI Seahawk GeForce GTX 1070 / amfeltec cluster x4 MSI Geforce 1080 Ti
- p3taoctane
Oh man I'd love to borrow that L > ))))
