i use win7 ultimate
master: 1x GTX680, Cinema4D (all versions)
clients1: 4x titan
client2: 4x 780
it was perfect with the 2.23.x versions.
with 2.24 the problems started.
also standalone crashes with network rendering enabled...
Please Otoy...
or anyone else has this problem?!
could it be any cloud rendering implementation problem?!
OctaneRender™ Standalone 2.24.1
- immortalartscom
- Contact:
Does that happen only once after you switched the version and after that the slaves come up reasonably fast? Or does it always take ages to start a slave? On which operating system is the master and are the slaves running?immortalartscom wrote:hey, thx for release. here network render worked always perfectly till 2.24.1... is it possible that there were some changes on your side? i use c4d plugin but ahmet ensured that this is a standalone problem.
the clients take very long to show up on master. so long that the first 10 times i tested it, i did not wait till they were there...
c4d also crashes because of that...
any ideas?
thx
I just gave it a quick try and it works fine here. What do we have to do to reproduce the crash?immortalartscom wrote:also standalone crashes with network rendering enabled...
I've only seen 2 client disconnects so far in 2.24.xx. No client errors. They just lost the connection while rendering and the client had to get restarted to find the master again.immortalartscom wrote:or anyone else has this problem?
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
no problem here with net render on v2.24.1 on both standalone and C4D plugin as well.
@immortalartscom: are you sure to have the correct combination of versions between standalone and c4dOctane?
- Elvissuperstar007
- Contact:
It is very necessary to HDR light DOME, quality hdrs all black bottom, it is reflected in the glasses
HDRS CG Souce the best !!!
There's not much we can do about those black reflections. There is just nothing in your scene to render in those places. You can't render the sky in those reflections, unless you want the appearance of a building floating somewhere in the sky. Normally in those windows you would see the reflection of the surrounding landscape but your scene doesn't have a surrounding landscape.
So what would you expect to be rendered in those windows?
Roeland
Roeland
- Elvissuperstar007
- Contact:
But in vray this issue has long been resolvedroeland wrote:There's not much we can do about those black reflections. There is just nothing in your scene to render in those places. You can't render the sky in those reflections, unless you want the appearance of a building floating somewhere in the sky. Normally in those windows you would see the reflection of the surrounding landscape but your scene doesn't have a surrounding landscape.
Roeland
octane limited in the number of polygons to 19 million
customers sent a very heavy scene, even 6-gigs card can not cope, and you offer me to make the environment))
in max is a function to use a selection texture
If you render an environment with the lower hemisphere being black, then of course, the reflections of that hemisphere will be black. So either put a floor into your scene or make the the lower hemisphere not black. If that's not your problem, then what is it?Elvissuperstar007 wrote:But in vray this issue has long been resolved
