Mix modo and octane workspace node
Flyx
I don't know how it works exaclty, but isn't it possible to use the map as some kind of multiplier for the power ? Like black value will result in power x 0 , and white value power x 1, that way it will not be too biaised ?
Does octane accept that kind of that kind of things ?
What i would like is having light like in HDR light studio for exemple, gradient, real light etc... But as i often need to do animation i can't rely only on hdr light studio, i need to be able to move light during the animation, so mapping images on light is the only way
Of course all of this keeping the unbiaised caracter of octane ^^
Win 11 64bits | Geforce 3090 RTX | RYZEN 9 5950X | 64GB
This can certainly be done in Octane (just use the node setup I posted above). However my understanding of your requirement is that you want to sync the Octane emitters exactly with the Modo lights - and at the moment that is not trivial. If you use the Create Octane Emitter for each Modo light you can then edit the Octane emitter material - however that will be independent of any changes you make to the Modo light intensity. I will post a tutorial in a few days showing how you can link Modo material channels to Octane inputs - which may get you closer to what you are trying to achieve.
Return to “Foundry Modo”
