Master scaling of multiple texture maps?
I also look forward to being able to use a combination of sunlight and HDRI environments
You can do this already. Attach a HDR image (via an Image node with gamma set to 1) to the Sky Texture pins of the Daylight node.
BenStorch
Great, thanks Paul,
I wasn't aware of that !
Sorry to ask for more, but advice on the following would also be much appreciated:
What's the best way of adding cast shadows to the hdri scene, short of photoshopping them in ?
Is there any way of creating a floor that's not visible but still receives shadows ?
In Cinema 4D, it's possible to set '(not) seen by camera' , '(not) seen by rays', is there something like that in Octane/Rhino ?
Lastly, what's the best way of creating a visible light glow, from something like a blackbody emission object ?
Many thanks, Ben
BenStorch
Just found the post-processing bloom, so that's answered !
wimvdb
BenStorch wrote:Great, thanks Paul,
Many thanks, Ben
Make the ground prop a diffuse material and turn on Matte (enable it). This will create shadows on the hdri
Or you can add your own prop and apply the same material
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
BenStorch
Many thanks for the advice, will try it out,
slowly getting on top of things. . .
Return to “Poser”
