OctaneRender® for Maya® 2.22.2 - 7.0 Win [OBSOLETE]
Refracty
So is the recent Octane plugin release running on Maya 2016 ?
JimStar wrote:Is Maya 2016 already available for all platforms?
Refracty
At least it is available for Windows.
Berge
Deja vu
Refracty
infinate loop
abeoctane
I found a bug with the mix material, when you reload the scene it looks like it only loads the top material of the mix, so when you render the scene your objects looks weird, you have to scrub in the mix bar so the botton material loads in the mix, and render as spected.
abeoctane
Thank you for report. I'll check it.
abeoctane
Hi Jim, I think I found another one, if you render negative sequence, for example from -20 to frame 10, all negative frames are numbered backwards.
connartist
If the Octane plugin for Maya 2016 (Windows) isn't supported yet, is there an unsupported way to install the 2015 version or something in the meantime? Thanks!
ivankio
Minor request: please consider bringing back the version number anywhere like it once was on the info screen on OctaneLive Account tab.
GTX 1080 8gb, GTX 970 4gb, I5 4590, Z97-E, 32gb RAM, Win 10 64bits, Octane for Maya
Return to “Autodesk Maya”
