Help with grain!!!! Interiors
glimpse
philliplakis wrote:
Thanks Glimpse always helpful :)
Would i lose any quality going about this route? or should i just bump up sample rate?
You will not loose any quality, just some lights will be more 'important' than others - that might be a solution in some cases.
Overall I'd go bit different route that is loosely covered in my signature (with free scenes), even if the scene is open You can use the same technique in interiors. Shortly speaking render bigger picture & use inbuilt noise reduction tools =)
philliplakis
ok. so i increase the sample rate of the lights to 600, set the PT to 6000 and i got the exact same result. I rendered it at 4K and tried reducing it to 2K but I'm not getting the results...
I don't was a super clear image but its just way to much noise... even a topaz denoise app can't remove it
Win10 - 6700k - 32gb Ram - GTX Titan X (Pascal) + GTX 1080
smicha
Can you PM orbx scene?
PS. Did you try to set GI clamp to 1-10 values?
philliplakis
smicha wrote:Can you PM orbx scene?
orbx? I'm on c4d how would i export that?
i set the go clamp to 250000 i think it was previously 1 million
smicha
set gi clamp to 1 and see the effect
itsallgoode9
smicha wrote:set gi clamp to 1 and see the effect
yeah, GI clamp helps things speed up alot. I just started messing with this setting today and can testify.
djart
@ philliplakis, just in case you didnt know, there is a nice c4d underforum here http://render.otoy.com/forum/viewforum.php?f=30
