OctaneRender™ for Blender 2.06 - 6.6 Win [OBSOLETE]
Alain
kubicki3d wrote:
Alain wrote:Tested a simple Scene with a Carpet (Particlesystem distributes a Carpetpatch over a Plane).
It works when I set the Emission Number to 10.
But when I set it to only (!) 100, then the hole Operationssystem gets very slow, almost frozen and it seems not to render (I did restart the Computer after >5 minuntes of waiting).
Hi Alain,
Set your carpet patch mesh type to Scatter, as in the screenshot below.
Hope this helps
Szymon
Thanks for the hint.
@JimStar
Why isn't this set automatically if an Object is used for a Particlesystem ?
The workflow at the moment makes no sence from my point of view.
Kind regards
Alain
Intel Pentium 2.8 GHz 2 Cores, 8 GB RAM, GeForce GTX Titan 8GB, Blender 2.72b, Win 7 64 Bit
Phantom107
Is it possible to import CSV files to do the scattering, so Blender is fast in the viewport and I can combine it with Phantom Scatter? I have some new features coming up and it would be awesome to be able to fully replace Octane standalone by Octane inside Blender. :)
This is a real shortcoming! Please look into this, I don't know how difficult it will be, but a CSV file is just a list of matrices that in the standalone, a Scatter node imports.
resmas
Phantom107 wrote:Is it possible to import CSV files to do the scattering, so Blender is fast in the viewport and I can combine it with Phantom Scatter? I have some new features coming up and it would be awesome to be able to fully replace Octane standalone by Octane inside Blender. :)
+1
Would love to have that.
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
Marten74
If some programming genious would create a plugin that converts Cycles materials and node trees to Octane materials and node trees, I would buy it in a whiffy!
Cheers!
::mb
Alain
+1
I would pay 100 $ for such a convertor.
Kind regards
Alain
Marten74
Alain wrote:+1
Kind regards
Alain
I´m with you!
ephdot
Regarding the material converter thing, +1.
With regard to materials, I'm also wondering if it is possible to do something similar to the standalone, where we can see all of the material slots in a list for a global mesh. Sometimes, it can be so tedious to chase down all of the materials in a scene. If it was presented as a hierarchy so you could see what mesh it is as well that would be nice.
Lastly, I know I've seen it mentioned, but I can't find it - does anybody know if installing the latest standalone (2.14) will bugger the current Blender/Octane version? Or more generally put, must we keep the Blender/Server and standalone versions in sync?
AMD-1100T 6 core, GTX-590 & GTX-480 1.5GB, 16GB 1600MHz RAM, 1TB WD 6GB/s, Win7 64bit, Blender 2.68a for Octane 2.2, Octane 1.20, Blender/Octane Server 2.2
ephdot wrote:With regard to materials, I'm also wondering if it is possible to do something similar to the standalone, where we can see all of the material slots in a list for a global mesh. Sometimes, it can be so tedious to chase down all of the materials in a scene. If it was presented as a hierarchy so you could see what mesh it is as well that would be nice.
What is the problem with Blender outliner?..
ephdot wrote:Lastly, I know I've seen it mentioned, but I can't find it - does anybody know if installing the latest standalone (2.14) will bugger the current Blender/Octane version? Or more generally put, must we keep the Blender/Server and standalone versions in sync?
It does not matter if you have another standalone version installed locally. It does matter only if you are using network rendering - in this case you must have exactly the same version of render slaves.
ephdot
Jim-
Thanks for the reply.
I don't really have a problem with the outliner view in Blender. I was just imagining a view similar to how you have the Live DB view. Perhaps a tab on that display named Scene Materials that shows the materials in the scene in a layout similar to the Live DB layout, with previews and so on.
That said, I know you have bigger fish to fry. I was just floating it as a "what-if" type of suggestion.
-ephdot
simdal
Thanks, simdal
Win 10 64, 4xGTX780ti 8xTeslaK80, Octane, Blender, Archicad
Return to “Blender”
