Andrew88 wrote:as the log says, it needs one more frame after animation ends. it´s a little cryptic about whether how to add the extra frames. I tried adding more frames in the timeline. that didn´t help, tried adding a few frames in the render output. that didn´t help either, keeps getting the same error above.
Hi Andrew88,
I believe this error has been put in place so that people don't get bad blur on their first or last frame because their animation stops or hasn't started moving. I would prefer it was a warning and the shot would render anyway. You have 2 options to get your shot to render. Either:
A - Extend your animation (not the time line or frame range but your actual keyframed motion at least 1 frame before and after the frames you actually need rendered. This is in truth the only real solution.
But:
B - If you already have handles on your shot you can just not render the first and last frame and then the render should go through.
As I said I personally think having the hard error is going to generate far more posts to the forum than just having a warning that Blur will be incorrect on first/last frames and letting the frames render. It's what all other renderers I've used do (in fact they don't even give warnings) and animators should know that they need animation before and after their shot to get correct motion blur anyway.
T.
