Is this a normal score for Titan Black?
rappet
julianb wrote:Thanks, rappet.
Don't sweat it if you don't have the time though, mate.
Have a good weekend.
Jules.
Hi Jules,
I tested Titan Black (not superclocked, but regular) on Octane 1.55 with Benchmark and got 6.96 Ms/sec.
The Titan is second card and not for monitor as well.
Maybe your Titan is losing but of capacity for monitor if you have it as first card?
greetz,
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
glimpse
my TB on v1.55 gives 6.05Ms/sec,
while in v2.1 ~6.6Ms/sec, but..
I know that my cards are capped: quickly opened GPUZ - near the bottom of sensors tab for GPU, You can find a field called "PerfCap Reasson" =) this will tell You why You card behaves as it does..- sometime it's thermal throttling, sometimes reliable voltage issues, sometimes power limit.. - check Your case =) in My case it was thermals (so I know that I need to provide more airflow to keep performance higher =) & as they say: clearly identified problem is halfway solved =)
julianb
Thanks to both of you, guys.
I will definitely download GPUZ and see if there is anything wrong. Although to be honest my result seem fairly good.
Cheers.
Windows 7 64bit| Intel 3930K| 2x GTX 460 @700MHz 2048MB| 12GB RAM
julianb
Just a quick last update- I ran the GPU-z and the PerfCap Reason field reads VRel (when the card is under load) and then blue colour on the right of it. Which from what I read on-line is a good sign.
Temperatures reach 80C when under load with fan speed at 50%, I don't think that is too high for throttling to occur, but then again- what do I know :)
Anyway- very happy with the new card, thank you guys for the help.
Cheers.
