What is the correct way to do a spot varnish?
itsallgoode9
ok, it is magically working now for me again! i have no clue what that hiccup was about...but yeah, now mix material works and I am able to combine two mix materials! I guess i just couldn't combine two mix materials earlier because mix material in general was acting buggy. hooray! Thanks
Intel i7-3930K, 64gb RAM, Asus X79 Deluxe mobo, 2x EVGA 780 6gb (for rendering), 1x PNY quaddro k4000 (for display)
Windows 8.1 x64, Maya 2014, Octane Render v2
itsallgoode9
what if I need a brushed metal metal with a high gloss varnish on it, for example? that would take two different layers of roughness but the materials don't seem to be setup to work like that.
is something like that possible?
gordonrobb
My gut feel is if you want that you'd be best using geometry. Have your brushed metal, then have the garnish on top, but very close.
itsallgoode9
you can actually do that approach using a mix material, in a test i tried but it was really noisy. i did one metal and one glass combined in a mix material. although it worked, there were lots of fireflies. is there a way to make a material that is clear, but has no refraction? there's not reason i need to treat a layer of varnish like a refractive material with all the extra calculations when it's only a hair thin and i think that would fix the fireflies.
any htoughts on that?
riggles
itsallgoode9 wrote:you can actually do that approach using a mix material, in a test i tried but it was really noisy. i did one metal and one glass combined in a mix material. although it worked, there were lots of fireflies. is there a way to make a material that is clear, but has no refraction? there's not reason i need to treat a layer of varnish like a refractive material with all the extra calculations when it's only a hair thin and i think that would fix the fireflies.
I believe you could set the index to 1, enable fake shadows perhaps, and also raise caustic blur to 1.
itsallgoode9
thanks, i'll check it out and see if that works. I did do a quick test setting the index to 0 but that took away all reflectivity, so I didn't even try anything else down that route.
