Random Texture Transforms over Instances
Forum for OctaneRender Lua scripting examples, discussion and support.
abstrax
One more thing: I hope to sneak in an additional non-interpolation mode to the gradient texture node, which would also help with this problem: http://render.otoy.com/forum/viewtopic.php?f=9&t=41451
smicha
Great. Thank you for your time and effort. This is all I need (except of more speed at PMC :))
smicha
abstrax wrote:One more thing: I hope to sneak in an additional non-interpolation mode to the gradient texture node, which would also help with this problem: http://render.otoy.com/forum/viewtopic.php?f=9&t=41451
To solve the problem it is just enough to create plain colored textures/images and use the LUA script :geek:
abstrax
You can just use a gradient texture node directly with some colors, but how I understand it, he wants to have only 2 colours (no interpolation), which you can't do right now. Providing a non-interpolation mode (basically a step function), you could achieve this though. It would also be useful in your case where you may not want interpolation between two consecutive textures.
smicha
Will you add the step function option to the code? (just asking, it is not urgent now)
abstrax
smicha wrote:Will you add the step function option to the code? (just asking, it is not urgent now)
It needs to be added to the gradient texture node of Octane. I think it would be useful and not too hard to implement - when we get to it.
smicha
Marcus,
One more question/wish:
random flip vertical, flip horizontal - are these possible? I think it is all about negative scaling, isn't it?
abstrax
smicha wrote:Marcus,
Yup, should be possible via a negative UV scale.
smicha
Marcus,
Could you please add the new feature to the script - selecting material files instead of a folder?
smicha
Any help with this ?
Return to “Lua Scripting”
