OctaneRender® for 3ds max® v2.03
perro_abombao
Hi!!! the port to max framebuffer button doesn´t work :(
oguzbir
perro_abombao wrote:Hi!!! the port to max framebuffer button doesn´t work :(
Same here...
My Portfolio
Karba
nildoe wrote: I just installed 4* GTX780 with 6GB, and updated to 2.03, and whenver i open the octane viewport the render gets stuck at 1 Samp/pix.
Nildo
kevinshane wrote: So am I! please fix that!
What 3dsmax version do you use?
Could some of your send me a simple scene with this issue?
[email protected]
I know, it sounds stupid, but I can't reproduce it.
Do you use Ornatrix or Hair Farm?
nildoe
Hi Karba
Using max2014..I will send you the scene in a while..although I have hair farm installe, in this particular scene not using it.
Its just a car im modeling.
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
nildoe
Karba i just sent the file over to you.
Nildo
coilbook
max still hands with 700 cuda error. after rendering i cannot just continue rendering another camera angle for example or scene. I have to close max and relaunch the scene to start new rendering to avoid that.
anifex3D
coilbook wrote:max still hands with 700 cuda error. after rendering i cannot just continue rendering another camera angle for example or scene. I have to close max and relaunch the scene to start new rendering to avoid that.
I am having this same problem. I can only render once per session of max. If I try to switch cameras or close the octane window and then re-open it errors. Also if I close the octane window and then try to use the max render it errors. This was also happening in v2.02 but not in v2.00.
https://anifex.com/ | Win 10 64Bit | i9 - 9920x -128gb ram | 4x RTX Titan 24gb | 3dsMax 2022 Octane Plugin
coilbook
i noticed that too. 2.0a did not have that problem
coilbook
also freezes with this error i never had before
CUDA error 715 on device 0: Error code unknown.
-> failed to deallocate device array
Karba
coilbook wrote:also freezes with this error i never had before
Have you replaced your power supply?
Return to “Autodesk 3Ds Max”
