Thanks Resmas. I did change the default location but this did not work either - BUT... you effectively solved my problem. Here's the story:resmas wrote:Hello again mate, when running the installer I have to set the directory where to install. The default option of the installer is C:\ProgramData\Sketchup|Sketchup 2014.... in my computer its not this directory. If I run the installer as default setting, it installs but doesn't show up in SU... the problem might be here C:\ProgramData\.
Lets see if Fuzzy can sort this.
cheers
resmas
1. Changed default installation location to C:\Program Files (x86)\SketchUp\SketchUp 2014\Plugins
2. So the installation works but it's but the new version is not visible in SU...
3. Move the files over from the Plugins folder to the TOOLS folder and voila!
So Fuzzy,
I am wondering why the default installation is the program data one when the default Sketchup folder is C:\Program Files (x86)\SketchUp\SketchUp 2014...?
Also, there seems to be some duplication with the Plugins vs Tools directory. Others seem to have no installation problems so I'm a bit lost here...
Best,
Seeker
