Select Color
However, the instant update still is missing. So, every time it requires to press OK to see the changes. Is there any possibility to have instant update?
The instant update is working for me for the Octane Viewport - but requires you press OK for the Rhino preview window to update the color. Is this not working for you?
it would be great to have a field where we can directly feed in at least RGB values or may be # color codes so that, copying and pasting color is more easy.
You can copy and paste RGB Color nodes by rightclicking them. I just noticed that pasting an RGB does not update the preview image, which I will fix. If you really need to enter numbers for a color, this can be done, but it is not a 5min change, so the Octane2 enhancements probably take priority.
jitendra
Sorry, I just rechecked the instant color update and now its working. Not sure it didn't work yesterday.
I just found copy paste option for color in Octane Render panel. And therefore the text input is not needed.
Thank you.
Good luck with Octane 2 features. Looking forward for that.
Regards.
Best Regards, Jitendra
Return to “Rhinoceros 3D”
