Clones Not showing And Rendering Samples
p3taoctane
Any news on this mate?
Peter
can't produce similar problem. It's good for me
p3taoctane
So when you render out the animation in Octane Render yo get ALL the clones (small blue balls falling at the end of the animation)??
Can you save the file and re-post it with your settings. If that is the case then it should also work on mine... are you r14 or r15
Peter
p3taoctane
Thanks mate
Tried opening your file.
Error reading resource
file 'C:\Program Files\MAXON\CINEMA 4D R14\resource\res\description\oinstances.res'
Line1
with OK as a button Choice...
can't click though it.. have to force quit.
Went to that directory and I do have a file called Oinstance.res... (note CAP Oinstances where as the error message says oinstance.res... i.e. lower case 'o')
I have Oinstance.res
and
Oinstance.h
can you put this res files?
p3taoctane
Love to man
Did not see anything attached : >)
p3taoctane
p3taResfiles.zip
(524 Bytes) Downloaded 222 times
Maybe you wanted me to give you mine...
If not
please attach the ones you wanted me to try
Peter
ok, i`ll check with these files. i don`t think that`s a plugin related problem
p3taoctane
Thanks mate
