OctaneRender™ for Blender 1.20.2 - 2.2 beta Win [OBSOLETE]
ephdot
Jim-
I'm seeing the same thing with multi-material objects. In my case, I have a mesh with three material slots. If I select the top material slot in the materials list, and then select a material from the Live DB, and click the Get Item button in Materials Live DB window, it assigns the material from the live DB to all three material slots for the mesh. The correct behavior should be to assign it only to the selected material slot.
I could send you a project if you can tell me where to post it. I don't see a way to attach a file to my message.
Edit - I found out how to attach a file, needed to zip it. The attached file has a couple of meshes that have multiple material slots. The cylindrical one at the bottom has three. If you select the top and do Get Item from Live DB Panel, you'll see that it changes all three.
-Dan
NewFrame_Octane3.zip
Blend file to show issue.
(249.15 KiB) Downloaded 271 times
AMD-1100T 6 core, GTX-590 & GTX-480 1.5GB, 16GB 1600MHz RAM, 1TB WD 6GB/s, Win7 64bit, Blender 2.68a for Octane 2.2, Octane 1.20, Blender/Octane Server 2.2
ephdot
Jim-
Sorry - I just found something else. Should the Octane Server be limited to a single instance? Each time I launch, I get a new instance. Typically in start-up code you can check to see if an instance already exists. If it does, use that. Otherwise, create a new one.
-Dan
afecelis
JimStar wrote:
afecelis wrote:Thanks a lot JS! It's working nice n' tidy! ;)
I just got one issue, with the multi-material object. Notice how I have selected "yaris-body" as active material (a red car paint), but when I select a material from the db, it applies it to a different material (yaris-glass_blac). In the screenshot I tried 3 materials from the db (blue dark, cherry red, green) and they all got applied to "yaris-glass_blac" (the borders around the window shields, in green in the screenshot).
Am I doing something wrong? Let me know if there's any other way I can help you out to track this issue down (if an issue at all, it may just be me using the program wrongly) :D
regards,
Alvaro
Can you give me some scene where I'll be able to reproduce it?..
Check ur pms ;)
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
rattle-snake
Hi again JimStar :)
Wouaw thank you again for this amazingly fast release =)
I would like to report you something.
I've done a little search with the particles and blender. And I saw this :
http://blender.stackexchange.com/questi ... -in-cycles
So at this time, it's only possible to see the smoke with the default blender renderer. My scene :
But with Cycle and currently Octane it seems impossible to have a correct render. Because there is no correct material available for the "domain volume" :/
So the renderer only show the mesh of the domain itself :
I know that you have tons of things to do, so... when you will have the time, it will be amazing !
Cheers
r4ytrace
sorry I still can't get it to work - exactly same as last time - 'waiting for image' and console says:
<!> event has invalid window
Octane: WARNING: only node-materials are supported
Octane: WARNING: only node-textures are supported
this is getting kinda depressing now :(.
I have latest Geforce Drivers. Can anyone thing of anything else it could be?
I actually just managed to get a material from liveDB so I at least know how that works now :) - but still even when it DEFINITELY has an Octane material assigned:
'<!> event has invalid window
Octane: WARNING: only node-textures are supported'
do I HAVE to create a plane with an emission on it too?
- ok I tried turning the default cube to a diffuse Octane material with emission and still the same errors :/.
I was just thinking - you know the tweak that was suggested for standalone Octane render to increase the amount of 'timeout' before Windows will crash from the gfx card? I might have that on, will I try turning that off (and how does one go about that :p).
r4ytrace wrote:sorry I still can't get it to work - exactly same as last time - 'waiting for image' and console says:
What GPU do you have?
dafassi
there are some issues using animated textures:
1- Loading AVI-Files as textures let Octane-Server crash when render or open the preview-window (material).
2- Loading PNG-Image-Sequences does work, but the render will not be refreshed. It seems that octane render all the time take one of the sequence´s images. Of course, i set the frames to 250 (for 250 images) and clicked AutoRefresh. The FrameCounter in the node is working- it counts the frames according to the actual blender-frame. But all the time, the render-window shows me an still image. I moved the camera a little bit to force a refresh- then rendering restarts- but also just with one frame.
3- A question about that. How do i have to set up a material to show me a alphatextures correct on a plane?
My animated texture is an imagesequence with 250 PNGs (incl alphachanel).
a- I create a Octane Duffuse Mat.
b- I connect an Octane Alpha Image Tex to the Diffuseinput of the node.
c- Tada, the image is on my object- but the alpha is not transparent!
Ive tryed all options and slider combinations from the nodes- nothing helped. Hope you can tell me what the right way would be ;).
For those that whant to try i attache a small image-alpha-seq and a alpha-avi-file!
Both in 400x300px @24FPS
Regards,
Dennis
SMALL_AVI.rar
And here is a loslesscompressed avi-file with alpha chanel. You need the free lagarith-codec to be able to use this video-file!
(3.82 MiB) Downloaded 268 times
SMALL.rar
This is a small PNG-Image-SEQ with ALPHACHANEL for Octane-Development and testers!
(3.69 MiB) Downloaded 265 times
WIN7 64bit • 32GB DDR5 RAM • Intel i7 6x4GHz • GeForce GTX780 • Blender
dafassi wrote:Hi,
Thanks for report.
I have not given too much worktime to animated textures so far... Will do it in next versions...
rattle-snake
Just a little thing I noticed.
In Cycle, there is an easy way to hide the planes emitting lights from being rendered :
How about Octane ? I'm looking for a solution
EDIT : Oww I have just found. Simply by putting a value of 0 into the opacity channel of the material :D
r4ytrace
JimStar wrote: What GPU do you have?
I currently unfortunately only have a GTX 260, but there is a GTX 660 on order which I should have by hopefully monday or tuesday :).
Return to “Blender”
