OctaneRender™ for Blender 1.20.2 - 1.4 beta Linux x64 [OBSOLETE]
grimm wrote:I'm having a problem with the absorption medium with specular material in Blender for Octane. It works in standalone but no matter what I do in Blender I can't get it to work. Basically I lose transparency when I hook up the absorption medium and it makes the object completely opaque.
Can you please send me this .blend scene from your post (with absorption medium problem)?
grimm
Thanks Jim,
Here is the .blend file.
beaker.zip
(1.65 MiB) Downloaded 312 times
stratified
grimm wrote:Well it doesn't look like a memory leak, my memory stayed steady at 3.0 GBytes used out of 8 GBytes.
If you see this on the standalone as well then I think I now what it is. This problem has do do with connecting to the OctaneLive server (It will happen more often if your internet connection is unstable). It's something that has been plagueing Octane on Linux for a long time but we weren't able to fix it yet because it only happens so often. I will monitor this more closely.
cheers,
Thomas
grimm
Thanks Thomas,
I didn't notice if I was having internet problems, especially to 127.0.0.1. I will keep a better look on that too. I did get another error when I was doing a lot of testing, but I had blender in the texture mode so it wasn't using OctaneServer. It was a sig fault, which might help you more?
jason@gemong ~$ /usr/local/bin/OctaneServer &
[1] 24201
jason@gemong ~$ ERROR: Program executed illegal instruction.. terminating
[1]+  Segmentation fault      /usr/local/bin/OctaneServer
Next version HERE.;)
Return to “Blender”
