OctaneRender™ for Blender 1.20.1 - 1.1 beta [OBSOLETE]
Alain
mib2berlin wrote:Hi Alain, change particle objects to scatter.
Srceenshot rendered with 100000 particles.
Cheers, mib.
Thank you mib ! :-)
Intel Pentium 2.8 GHz 2 Cores, 8 GB RAM, GeForce GTX Titan 8GB, Blender 2.72b, Win 7 64 Bit
MattRM
Hi all,
Does the plugins support motion blur ?
Matt
mib2berlin
JimStar, the settings and explanations for Octane Properties, Global, Scatter, Movable proxy and so forth is missing in manual.
Multo importante for new user. :)
Cheers, mib.
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
tungerz
mib2berlin wrote:JimStar, the settings and explanations for Octane Properties, Global, Scatter, Movable proxy and so forth is missing in manual.
Cheers, mib.
+1
Are there any tutorials floating around for it as well?
I saw that Radiant mentioned making some.
BTW, thanks MIB, got it running :)
~Tung
Win7 64bit...Q6600 Quad core...8Gig Mem...9600 geforce...Daily Build Blender2.5x...Lionel's(Yoyoz)1.10 Blender Exporter... 0 Skill=Priceless
mib2berlin wrote:JGlobal, Scatter, Movable proxy and so forth is missing in manual.
Cheers, mib.
They are in manual. In rendering section.;)
mib2berlin
Hah, I search every where but not in render section but it is definitively a render setting.
Thanks JimStar, mib.
MattRM wrote:Hi all,
Found a little bug (or not). When I use subdivision surface, I uncountered black patches / triangles into the surfaces. It's make an alpha hole (cf. screenshots).
Yes, I know that the internal Octane subdivision may still have some issues, I'm still developing it and experimenting with different algorithms - thinking about OpenSubdiv integration to process it fast on GPU... It is just not the most important thing which should be implemented among others, as there are standard Blender subdiv instruments to use so far (and you can use them instead of using Octane internal subdivision) - so, e.g. Live material DB I think should get more of my attention at this time.;)
When all the most important things will be finished - I will pay more attention to internal Octane subdivision.
Matt
It will be implemented later, as the Octane engine does not have this feature, and I should code the special plugin's module for it. It's a big work.
mib2berlin wrote:Hah, I search every where but not in render section but it is definitively a render setting.
I will make the manual more structured a little later... These things should be visible in TOC section...
mib2berlin
Hi, you write "The LiveDB is not supported by current version of Plugin.".
Is it planned to integrate the LiveDB during the Beta time or for later after stable.
Cheers, mib.
Return to “Blender”
