Thank you Paul for your answer!
I don't have any crash at tis time.
I have to try on the 2014 version now.
That's too bad that we can't use the revit link with 3dsmax for octane materials.
Regard
OctaneRender for Revit Beta 1.20a [OBSOLETE]
This is the ones from the forum I tested, thanks for the help.face_off wrote:Hi Sauger - can you pls post here or email ([email protected]) the csv file, and I will rectify the issue.
- Attachments
- Sample Transforms.zip
- (84.96 KiB) Downloaded 402 times
3x I7/16gb/GTX570/XFX5870/GTX Titan
Hi Sauger - those CSV files load for me. Could our Windows configs be different? Maybe Revit is using ',' as a decimal point? What is your Windows -> "Control Panel\Clock, Language, and Region" ->'Region and Language" -> "Additional Settings" -> "Numbers" set to pls?But when try to add a csv file I get an error.
Same file works fine in Archicad plugin, and standalone.
Small update - primarily to assist with any non-English Revit version issues. You can download this patch from the original download link at the top of this thread.
1.20a6
- In the event that the plugin cannot save data to the Project Browser, debug info is sent to the Revit journal file and a message is displayed to the user as to the whereabouts of this file. If you get this msg, pls send the journal file to me.
- Rectified issue loaded CSV scatter files if the decimal point is ',' in the Windows settings
1.20a6
Post removed.
Hello I have a Russian version revit 2014. Octane error:
Project Browser element not found. Unable to load Octane data the Revit scene file. Refer to c: \ Users \ ALEX \ AppData \ Local \ Autodesk \ Revit \ Autodesk Revit 2014 \ Journals \ journal.0051.txt for details. My journal file https://docs.google.com/file/d/0Bw1G_7W ... sp=sharing
sorry for bad english
Win7x64/i7-970/24gb/gtx580/gtx titan/3dsmax2014,2015/Revit 2014,2015
Hi. Thank you for posting the journal file. Unfortunately my PC will not read the character encoding - but I will install the Russian version of Revit to get this fixed for you. I will post the fix tomorrow. In the meantime, you will be able to use the plugin, but the Octane data will not save to the rvt file.Hello I have a Russian version revit 2014. Octane error:
Hi avidia64
I have not been able to install the Russian version of Revit on my PC (it wouldn't install - unsure why). However I believe I have still been able to fix the issue. Can you pls download and install the following version and tell me if it resolves your problem?
- OctaneRender for Revit 2014 1.20.1 beta RUSSIAN (64 bit)
