Ok, will check which dll´s are needed for the cuda stuff...
face
Free Soft2Octane2013 [Obsolete]
http://vimeo.com/user2509578
Hi Face,
Plugin seems to be working great - very fast obj export. Just noticed something with the camera, I'm using Optical Centre shift in the Projection Plane tab of Camera dialog to get 2-point Perspective. (Camera Y and Camera Interest Y are set to the same - optical centre shift is then used to get everything you want in shot).
This is also possible in Octane by using lenshift, but I noticed that the number in Octane and in softimage seem to be quite different, so I'm wondering if that is why it doesn't get sent to Octane?
SI seems to use inches for this lens shift, I'm not sure what Octane is using...
Cheers.
Cheers.
win 7 64 | q6600 | 4gb ram | gtx 260 [196] | driver nvidia 197.13 | SketchUp7 | Softimage 2010
win 7 64 | i5-2500k | 16gb | gtx 570 | driver 275.33 | SketchUp8 Pro
It is, monday...
face
face
Ok, there was a little delay.
The release day is...
WEDNESDAY!
face
WEDNESDAY!
face
Hey face,
I tried to install this latest version of your plugin, to get the 1.20 version of octane running. But when I install the plugin, there is no "Soft2Octane" showing up in the upper menue bar.
I'm using Softimage 2012 SP1, can you give me a hint what to do?
Intel i5 2500k@4,5 Ghz | Asus P8Z86-V Pro | 16GB DDR3-Ram | Nvidia 580GTX GDDR 3GB | Win7x64 | Softimage 2011 SP1 x64 | Octane 2.52 x64
Are the MS Visual C++ 2012 Redistributables installed?Mugga wrote:Hey face,
face
I had 2005, 2008 and 2010 installed, now installed the 2012 version of MS Visual but nothing changed. An older version of you plugin works, but I can't get it working with octane.face wrote:Are the MS Visual C++ 2012 Redistributables installed?Mugga wrote:Hey face,
face
Have you read the second last post on the first page from this thread?
Maybe the cuda staff is also your problem.
There is a link to a 64bit version without some cuda stuff.
Will link it to the first post...
face
face
THX, that worked.face wrote:Have you read the second last post on the first page from this thread?
face
