OctaneRender® for 3ds max® v1.12[Test]
After change the appearance of the camera (or modify the material), you have to press the update in the window of octane. Before the update automatically.
Core i5 76o @ 2.8o GHz | ZOTAC gtx58o AMP 1536Mb | MSI gtx46o 1o24Mb | Corsair ForceGT SSD12o | Gskill 16Gb RAM 16ooMHz
Actually mine works fine ..Vanya wrote:After change the appearance of the camera (or modify the material), you have to press the update in the window of octane. Before the update automatically.
My Portfolio
Me too. Sometime it work, sometime not. Sometime it cause my max crashing.Vanya wrote:After change the appearance of the camera (or modify the material), you have to press the update in the window of octane. Before the update automatically.
Karba, it's possible to implement support for standard 3ds max textures with RenderBitmap() function in near feature?
http://docs.autodesk.com/3DSMAX/15/ENU/ ... 172793e4e4
Win 7 x64 | GTX560Ti | Core i7 960 3.2GHz | 24GB RAM
- thomasmesser
I have got black render window (frame buffer) during render
JPG files are saved correctly...
Same here... This didn't happen before...Vanya wrote:After change the appearance of the camera (or modify the material), you have to press the update in the window of octane. Before the update automatically.
AutoCAD,Revit Architecture, Max Design (all 2012) , Moi3D,Maxwell Render,Octane Render
Intel i7-8Gb RAM - Win7x64 - GTX550Ti
Hi karba
I have big problems since I try 1.12
For all the scene i build before, I have a popup windows "unkonw system exception" when the scene opens and then the file is corrupted and can't be reopened.
It's very annoying cause i have to rebuild all the scenes from scratch
The biggest problem is that if i come back to version 1.11c, the errors occurs too.
I work on 3dsmax 2012 64b french and english.
- gabrielefx
here I read 224. The GTX 680 doesn't support so many textures.oguzbir wrote:gabriele,gabrielefx wrote:thank you!
does 1.12 support 224 textures? Titan textures number?
I havent read or know that titan had larger texture limit.
In 1.12 Titan shows support a total of 232 textures so as gtx680's and other keplers. (144rgba+10rgb64+68grey+10grey16)
http://www.bit-tech.net/hardware/2013/0 ... rst-look/1
