What directory is the Octane Prefs Kept
p3taoctane
The icon on the task bar was just the error message... once that is gone I got nada
if I just run octane from the terminal I get a Unnamed Project -Octane Render 1.10 and no file menu or anything where as I do get that when I launch it from an icon
Hoping this helps so I can be up and running by Friday : > ))
p3taoctane
If I go to Octane 1.11 on my desktop and run from a terminal octane no-opengl
I get the same error message but I can't click it to close and quit it freezes the process and I have to force quit
abstrax
p3taoctane wrote:If I run octane no-opengl from a terminal I get the splash start-up Screen then:
File error
no-opengl
The command line would be
octane --no-opengl
Notice the two dashes they are important. If you do that you wouldn't get the error message.
p3taoctane
OK that launched it
Benchmarking at 157.10 : > )
Now icon works also... what magic did we do by doing that
Peter
abstrax
p3taoctane wrote:OK that launched it
Peter
This command line parameter disables OpenGL for the viewport and enables a fallback solution using standard windows drawing. You can set this option in the preferences, but if you can't reach it, because the UI is stuffed you can use the command line argument to get around the OpenGL issues. To make it persistent, just open the preferences and click on OK.
So it seems that your driver/hardware setup is causing the issues. Which hardware are you using?
p3taoctane
Thanks ... makes sense... got me a couple of titans and a 690... added a third titan and that happened... could be that aye,
