Canvas Size
Moderator: BK
I have found that, if I have an aspect ratio set, when I enter a value for width, height does not update. If I then click on the plus button to bump it up a bit then the height gets recalculated. I need to double check if this causes the render to update the canvas size.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
this may indeed indicate, that the last change in this area did mess something up. if i can get back to my code, i'll see if this is a quick fix to release (most probably)...Sighman wrote:I have found that, if I have an aspect ratio set, when I enter a value for width, height does not update. If I then click on the plus button to bump it up a bit then the height gets recalculated. I need to double check if this causes the render to update the canvas size.
