Canvas Size
Forums: Canvas Size
DAZ Studio (Export Script Plugin developed by Tugpsx; Integrated Plugin maintained by Paul Kinnane)
Re: Canvas Size
Postby Sighman » Fri Mar 29, 2013 2:56 am
Sighman Fri Mar 29, 2013 2:56 am
I have found that, if I have an aspect ratio set, when I enter a value for width, height does not update. If I then click on the plus button to bump it up a bit then the height gets recalculated. I need to double check if this causes the render to update the canvas size.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Sighman
Re: Canvas Size
Postby t_3 » Fri Mar 29, 2013 3:01 am
t_3 Fri Mar 29, 2013 3:01 am
Sighman wrote:I have found that, if I have an aspect ratio set, when I enter a value for width, height does not update. If I then click on the plus button to bump it up a bit then the height gets recalculated. I need to double check if this causes the render to update the canvas size.
this may indeed indicate, that the last change in this area did mess something up. if i can get back to my code, i'll see if this is a quick fix to release (most probably)...
t_3
Previous
Return to DAZ Studio
Fri Oct 23, 2020 12:17 pm [ UTC ]
