Grass Shader
p3taoctane
yep that answers it. many thanks
peter
mbetke
Looks great. I use also a Mix material for such.
Diffuse has a transmission map with a more saturated and brighter version of the diffuse.
The Glossy material gives the highlights and reflection. Works well too. :)
I like the idea to test the material on a sphere.
PURE3D Visualisierungen
justix
Great! has it been submitted already? love to test it...
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
ronjart
I would submit it if I knew how. :?
kavorka
ronjart wrote:I would submit it if I knew how. :?
In the stand alone version, you right click and choose "save". Then under location change from macro to LiveDB.
ronjart
No way of doing it from 3ds max? Does that mean I have to rebuild the material or is there a way to transfer?
justix
ronjart wrote:No way of doing it from 3ds max? Does that mean I have to rebuild the material or is there a way to transfer?
need to sort this out...karba were are you?
ROUBAL
If you have made your material in the Node inspector, just right click on the pin of the node and copy it.
Then paste in the Node graph window. Create a material Macro. You will get a macro node with an output pin (not usable for export).
Double click on it, and a Macro node with input pin will be created in an other tab (I tell you from memory and so I may be not accurate, because I am not on my workstation, and I have not Octane on this machine).
In this tab, paste the Material node just above the Material Macro node with input, and connect them together.
Once it is done, right click on the Material Macro node with input and save it to the Live DB.
The template display in the live DP will be created automatically, but may require some days to appear. First, you will get a grey cross instead.
ronjart
Thanks for the help. I've rebuilt the material in the standalone version (it's a simple materiel) and submitted it. It's under Organic/Vegetation/BasicGrass. I had to upload two version, the first one is faulty (the mix map is no inverted) I hope that they'll keep the one I last submitted.
As I've mentioned, it's a pretty basic material so it would be nice to see your guys' modifications.
Seekerfinder
Thanks for sharing, ronjart!
Seeker
Return to “Works In Progress”
