Lightwave 3D Plugin v0.2
sjonsjine
holocube wrote:sjonsjine could you open up "edit plugins", see that you have OctaneExport.p in there with a layout command called OctaneExportOBJ ?
Hmm that's weird, I see OctaneExporter.lsc but not OctaneExport.p.
When I try to add OctaneExport.p it says Plugins were not found or could not be added.
Any idea what is wrong here?
sjonsjine
Oh no for some strange reason I see that my LW is the 32bit version and not the 64.
I will fix this.
But on my notebook I have the 64bit version of LW9.6 and your latest v02b installed.
When I click render it opens the saved octane project and renders it but not with my LW camera.
And, when Rendering Animation, all images are black, so I think there must be some cam export problem somewhere.
Any idea?
holocube
sjonsjine wrote:When I click render it opens the saved octane project and renders it but not with my LW camera.
You mean position and rotation is not correct when octane is opening?
GTX260 Seven 64bit
I'm Superfrog
sjonsjine
Let's start all over again.
-I have a lw scene with one lwo object in it, tripled.
-In your octane exporter I give it a project name like test5
-Resolution and Export Camera checked/ chosen
-When I click your render button Octane opens and I only see a gray background, can't see my object in the rendering. When I open (for checking) the test5.obj in Lightwave then I see that the object has been exported/ converted to an obj file and has done it correct.
So how come that in Octane it does not show up? I can't find it. Has it something to do with the Camera? Aim (nul) object?
holocube
Most likely yes, you can pick your mesh as POI item aswell but usually I create a null and place it in the middle of the mesh.
You don't need to check resolution in the exporter.
GTX260 Seven 64bit
I'm Superfrog
sjonsjine
holocube wrote:Most likely yes, you can pick your mesh as POI item aswell but usually I create a null and place it in the middle of the mesh.
I found something, maybe helping me is now more easy.
In octane the camera position is exact the same as the target.
When I change the x and y in octane the object is coming in range.
Any idea?
Thanks mate, Sjonsjine
geo_n
Any idea?
please upload files so we can check. :mrgreen:
sjonsjine
Any idea?
My rar file. Included are lw96 scene, lwo, exported obj en ocs.
As I mentioned before, the camera position is exact the same as the target position (in octane), when changing the x and y a little you will see my object in octane.
What happened here?
export-render-test.rar
(13.39 KiB) Downloaded 550 times
holocube
Markus and sjonsjine
Could you guys try v02c, before exporting go to "Lightwave Exporter Settings" tab and click on the "output logfile" button. select where to save the log.txt and then export. send me the log please.
sjonsjine: I opened your scene, selected the aim null as POI and exported. Came up the same in octane. Maybe you're relinking the ocs to an old project. Could you give your export a "fresh" project name and hit export?
GTX260 Seven 64bit
I'm Superfrog
sjonsjine
My logfile:
LogFile created
Render button pressed
Unitsize is 4
Exporting using Johans exporter
Check if written obj is in temp:
C:\Users\Freddy\AppData\Local\Temp\octanemerge.obj
File is there
Launching Octane
POI:
POI:
MyCam:
dist: 9.51884
AimposX: 12.8021
AimposY: 3.36998
AimposZ: 4.36312
-m eraf-octane-test01.obj -r "C:\3D\Projects\2010\export-render-test\\eraf-octane-test01.obj" --cam-pos-x 12.8021 --cam-pos-y 3.36998 --cam-pos-z 4.36312 --cam-target-x 12.8021 --cam-target-y 3.36998 --cam-target-z 4.36312 --cam-aperture 1 --cam-fov 31.8908 "C:\3D\Projects\2010\export-render-test\\eraf-octane-test01.ocs"
Return to “Lightwave 3D”
