How to use fog
mbetke
Whats happening with Mr.PMC here?
It is much faster than Pathtracing but gives big blotches which go fullbrigt. I had to reduce scattering to 0.1 and scale to 0.05 to reduce it a bit.
But look is totally different as PT.
PMC goes mad after 80 samples or so.
PURE3D Visualisierungen
gueoct
princedragoncok wrote:Everything goes out of focus when I put it in a bigger scene and the focus picker doesn't seem to solve the problem.
The Focus picker can only pick the sphere, of course...
hide the sphere - focus - unhide the sphere!
sucks, but i don´t know a different way...
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
mbetke
You need to use the camera target. Or lower the aperature on a large scene.
FooZe
mbetke wrote:Whats happening with Mr.PMC here?
Hi Mbetke,
This can be normal for PMC for low samples per pixel, try leaving it to render out some more, at least a couple of thousand spp. Hopefully it will level out to be more similar to PT.
Chris.
Tugpsx
I like the rays, as you have shown them.To get this working, does the light have to come into contact with the sphere
mbetke
No it just gets brighter and brighter. No changes and very unusual if I compare with other PMC renderings. I had this bright blotches phenomenon last time if I use too bright HDR images.
JuM
Karba wrote:
JuM wrote:However it can not be used in big scenes.
Really?
What about that?
Fantastic!!! thats what i mean exactly:D
Karba could you please share the settings? or max file!!!
noelnoel
I always try to make images as fast as possible, modified file attachment with fog, direct light ambient oclusion
OctaneFog directlight.zip
(41.75 KiB) Downloaded 423 times
retmia
noelnoel wrote:I always try to make images as fast as possible, modified file attachment with fog, direct light ambient oclusion
Thank you very much, it really fastens the renders!
Is there a way to increase the fog density so that at a distance of around ten meters in an outside scene we start to only see the fog ?
retmia.net
retmia.blogspot.com
i7 3930k - 2x ASUS GTX590 - 16GB DDR 3 - Corsair AX1200
ACantarel
-resloved
Return to “Autodesk 3Ds Max”
