i'm trying with LWHC build 2015 and after having to hit for each exported OBJ, in the end i'm always getting 'failed to copy obj' error, no matter what scene i'm trying. i'm just using LW object exporter because on mac, with default settings of exporter plugin.
cheers
markus
Lightwave 3D Plugin v0.1
let's debug over skype markus
just as a quick test before I can escape the office.. could you load a single object, select it. Open up lscript command in master plugins, in command enter SaveWavefrontObj
press enter and let me know if it exports fine
GTX260 Seven 64bit
I'm Superfrog
I'm Superfrog
can I use it in LW 9.6?
my obj writer(win) should work fine in 9.0 or later
GTX260 Seven 64bit
I'm Superfrog
I'm Superfrog
I get the message, unknown command "Generic_OctaneExportOBJ"holocube wrote:my obj writer(win) should work fine in 9.0 or later
Help......
yes it does!holocube wrote:let's debug over skype markus
did you add OctaneExporter.p ?sjonsjine wrote:I get the message, unknown command "Generic_OctaneExportOBJ"holocube wrote:my obj writer(win) should work fine in 9.0 or later
Help......
GTX260 Seven 64bit
I'm Superfrog
I'm Superfrog
good, my fault = fix3dworks wrote:yes it does!holocube wrote:let's debug over skype markus
GTX260 Seven 64bit
I'm Superfrog
I'm Superfrog
yes, I really don't get itholocube wrote:did you add OctaneExporter.p ?sjonsjine wrote:I get the message, unknown command "Generic_OctaneExportOBJ"holocube wrote:my obj writer(win) should work fine in 9.0 or later
Help......
On my other machine, 2nd license, I get the error: MeshNode for rendring "bla-bla.obj" not useable.
