Octane Sketchup Exporter Beta cc [superseded]
Burkhard
Yep, sliders work
Tomorrow I will change to Windows, to see the differences.
MacPro Quad * 8Gig RAM * GTX 285 Mac Edition ( delete two GT120 to make it run with octane! ) * Snow Leopard 10.6
MartyMart
Hi
My specs are in my signature...
I originally was happy that this version worked in the sense that the dialog was populated.
Having played with it I can confirm that I have the same issues as my fellow user.
But to me they are not major issues. At least I can load a scene in to Sketchup,
call up your system and press render and away I go.
Sorry I can't be more help, but at least I can tell you if it works for me or not.
Cheers
OSX 10.6.4, Imac 3.06 GHz Intel Core 2 Duo, 8 GB Memory, NVIDIA GeForce 9400
TIG
Thanks MartyMart [I see your specs in the signature :oops: ]
Sounds like your's is as bust as Burkhard's.
IF the MAC version were running like the PC's, when you first use the tool in a new SKP, then the dialog would populate with the correct defaults - i.e. default project name and path etc and almost all options unchecked except for the camera, you then change some things and those changes are remembered that session, if you rerun the tool; then if you save the SKP the settings are remembered as attributes in the SKP and when you next use the tool those are used instead of the standard defaults...
The dialog's "populate" should work exactly the same on a PC and a MAC - as it's using html/js etc, but it's not :cry:
I will sort this so that both OSs have the same setup... :roll:
TIG
Return to “SketchUp”
