THAT'S A FEATUREteknofreek wrote:Thanks for your efforts Frederik!!![]()
At present v1.04 is working basically fine for what I want.
There is an odd behaviour if I render one mesh (chicken that I used before), delete it and load a different mesh (robot mech) into modo and re-render using the script. If I load the ocs file directly into Oct that is generated without changing the project name (ie overwriting the first file(s)), it has the "mech mesh" but has the textures and colours of the chicken ie white yellow and red.. A bit wierd and I haven't explained well here, but haven't done a lot of checking. Oh and btw I may be doing something wrong, I'm still pretty newb with modo.
It's as if the uv's are funny.. so just take this as a comment and when I've got some more concrete data, and/or proved it wrong.. I'll post specifically.
Thanks again!!
It's just fine, that's how it suppose to work. If you want new materials from modo to be exported you either need to delete the ocs file or change the project name.
