OctaneRender® for Poser beta - build 1.02p [OBSOLETE]
Michael314
wimvdb wrote:This new version sometimes does not start rendering when you open de viewport. No idea why
Just refreshing the scene makes it start.
This happens also when you start the plugin (which should read the entire scene since it has all the changes), but the viewport render opens and does nothing. Press refresh and then it goes.
If nothing was changed in the plugin this must be caused by the new octane version
No big problem, just something to look at
thanks for the hint to just refresh. I had the same issue, but only the first time after booting the computer.
So far I always closed Poser completely and reopened it, after that rendering starts as usual.
This is since 1.02.
Currently postprocessing settings are not saved, but also no big deal, as I usually experiment a lot with the settings. It's a nice thing that you don't have to redo the render for a different glare/bloom setting.
I combined the BB EnvSphere with an alpha map and got a combined environment map / daylight effect, which is quite useful for the bloom/glare effect. I think that was asked for by a lot of people. I upload a thumb for that (larger render in my Rendo gallery).
Best regards,
Michael
Win XP 64 | GTX 580 (3 GB) | Core2Quad 2.83GHz (Q9550) | 8GB
Win7 Ultimate 64 | GTX 680 (4 GB) | Core i7 X980 | 24GB
I didn't believe you, but I just checked - and you a right! Actaully, the postproc settings are saved - however they are not being loaded correctly. I will fix this in the next version.
EnvSphere + alpha - that's a good idea!!!! I never thought of that.
wimvdb
Michael314 wrote: I combined the BB EnvSphere with an alpha map and got a combined environment map / daylight effect, which is quite useful for the bloom/glare effect. I think that was asked for by a lot of people. I upload a thumb for that (larger render in my Rendo gallery).
How do you set that up? Did you create a special alpha map for it so the daylight gets through?
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
Michael314
yes, I used gimp to set all areas of the sky to transparent. The "Fuzzy select tool" was major help in that process.
Best regards,
Michael
wimvdb
Michael314 wrote:Hi,
Best regards,
Michael
Ok, thanks. That isn't too bad I guess - you can get by with a few sky textures and you can eliminate the sun as well and keep the clouds a bit transparent so the light gets through and rotate for variation.
Cool idea!
wimvdb
One more question regarding this
Have you found a way to get rid of the artefacts (showing the mesh) with a skydome/sphere?
Zay
Was playing with instance when I got this error when moving a slider.
If I save the scene after getting this error I lose all the instances settings.
Traceback (most recent call last):
  File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 3898, in EventLooseFocus
  File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 4730, in EventNodeChanged
  File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 6542, in saveToDictionary
  File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 6072, in savePinInfoToDictionary
  File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 6067, in savePinInfoToDictionary
WindowsError: exception: access violation reading 0xFFFFFFFFFFFFFFFF
And the log file.
log.zip
(30.71 KiB) Downloaded 315 times
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
Zay
Got another one while moving the camera:
  File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 8861, in poserEvent
  File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 8483, in setCameraFocus
KeyError: 'usePoserFocus'
Thanks Zay
For the first error - did you happen to get the cuda.log file?
Zay
face_off wrote:Thanks Zay
There was nothing in the cuda log other than the usual "Opening OctaneRender for Poser Setup Dialog".
These are random errors but I get them now and then.
Return to “Poser”
