Octane Render 1.022 beta2.2 RC3 available [obsolete]
ROUBAL
Hi !
Thank you for your efforts. I have downloaded it some minutes ago, and I hope that I will be able to test it a bit tomorrow, but I will be very busy for 3 days and I will not be able to do much tests and to post comments until the end of the week. I'm sure that I will have a lot to read here then ! ;)
radiance
well, this should be the last one, this will be v2.2 final if there's no major issues.
we need to move on to 2.3.
Radiance
andrian
Radiance I notice that if I use diffuse or specular material for walls on my test scene results are quite different:
diffuse walls - beta 2.2 RC3 samples 4.97 ~ 4.6 / 7.0 ~ 6.8
glossy walls set to high roughness/low specular - beta 2.2 RC3 samples 5.22 / 7.46 :O
and results are visually the same ;)
I'st not much but it's faster than beta 2.1 for sure....
Vista 64 , 2x Xeon 5440 - 24GB RAM, 1x GTX 260 & I7 3930 water cooled - 32GB RAM, 1 x GTX 480+ 1x8800 GTS 512
CGsociety gallery
My portfolio
My portfolio2 - under construction
Web site
Making of : pool scene - part1
radiant
radiance wrote:well, this should be the last one, this will be v2.2 final if there's no major issues.
Radiance
wow you are really pushing yourselves with this.
Is this just a personal goal to get a FINAL release as soon as possible?
Or do you have superiors out there sending "Hurry up" emails :?:
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
radiance
Radiance
no, we need area lights and MLT asap...
Radiance
kubo
"direct sunlight through opacity mapped geometry is not working yet"
About this, could we have in the future, when DL works with opacity a material or a material modifier type of thing to block DL? I think it could be useful, it is for me, I'll post an image in wip later on what I use it for. I mean, a totally clear material or a matte one that doesn't show up but block the sun just the same.
enricocerica
Great release.
Two small things:
When you use the zoom picker, the image shift and you loose your actual camera location
When you've reached the texture limit during loading you get several messages stating that the new texture cannot be loaded, the problem is that all those messages still appear when you change a material, switch form direct lighting to path tracing, ... which is really annoying espacially when like in my scene you have to cancel many of those messages.
http://www.myline.be
SheepFactory
Working wonderfully on my end so far. The slowdowns are gone so are the flashes.
Great job Octane team!
http://www.alimation.ca
Win 7 64 bit
Gtx 275
i7 920
6gb ram
Driver version: 197.13
radiance
enricocerica wrote:Great release.
Two small things:
try to drop all repetetive textures and use procedurals ?
Radiance
face
Not realy important bug.
--version shows 1.021 ;)
face
http://vimeo.com/user2509578
