Quick translucency tests
radiance
you need to apply the registry fix here for rendering swith longer passes: http://www.refractivesoftware.com/forum ... f=21&t=824
Radiance
Proupin
wow, stunning...
one thing though, next to the RGB Spectrum Drop down menu it should read "transmission" instead of "RGB Spectrum" right? ;)
lixai
radiance wrote:you need to apply the registry fix here for rendering swith longer passes: http://www.refractivesoftware.com/forum ... f=21&t=824
Radiance
hey Radiance, is this a bug or what... i tried to reproduce and didn't succeed. but i want this effect. This is allso a request, can you make a 2sided node for the normal direction and a blend tecture tu mix those two... this way we can mimic the effect of translucency.
this tutorial is an example of what i mean.
http://www.peterguthrie.net/blog/2009/1 ... al-leaves/
Core i7 860, ZOTAC GTX 580 - 3GB, 2 x GTX TITAN, 32Gb RAM
radiance
Radiance
It's not a bug, it's a feature, you just need to make a diffuse material node, connect it to your material input on your object node, and connect a texture or rgb spectrum to the transmission input, then you can play with the sliders of both reflection and transmission to get the desired effect.
also, you must enable pathtracing to see the effect as directlighting does'nt show it.
Radiance
n1k
@lechu
I got inspired by your tests and did few my self. Hope you don't mind for posting my results here:)
n1k
P.S. Can you do a render with a whole tree in a shot?
[email protected], 8gb RAM, Gainward GF 460 GTX 2048mb,Win7 64bit.
http://continuum3d.blogspot.com/
Proupin
Proupin wrote: one thing though, next to the RGB Spectrum Drop down menu it should read "transmission" instead of "RGB Spectrum" right? ;)
Just in case this doesn't go unnoticed, although it's minor, perhaps it was not clear what I meant :P... In the node inspector, where all the material channels read "diffuse" "bump" "normal" etc... in the first image (the screenshot), where it should read "transmission" it reads "RGB Spectrum"... cheers!
lechu
n1k sure, let's post here our results :) I'll try to make some full tree shots later and maybe some bush scenes.
Proupin, I think I know what U're talking about hehe. In my case Octane sometimes displays (in material tab) diffuse or transmission or RGB spectrum sign, don't really know why. The point is to have two float/rgb sliders, one above the another and be sure one controls diffuse color, and the other shader's transmission.
Radiance thanks for info :)
radiance
n1k wrote:@lechu
n1k
the tree bark looks like it's made of metal :)
Radiance
n1k
Hmm. It's diffuse material with betula bark texture, although I rendered little robot recently so I might be under that influence:) hehe I'll try with diferent texture tomorow:)
n1k
n1k
Here's quck wind simulation. Motion turned out a bit funky:)
n1k
[vimeo]http://www.vimeo.com/11972870[/vimeo]
Return to “Works In Progress”
