very cool.
how are you retrieving your images ? are you manually saving and closing octane per frame ?
Radiance
							ICE
Relative simple...radiance wrote:very cool.
Radiance
I export the obj, playing with settings and save the ocs. Because, if Octane crashed, i have a backup.
Render, save image, export new obj with the same name, reload it in Octan, render again...
http://vimeo.com/user2509578
jesus !face wrote:Relative simple...radiance wrote:very cool.
Radiance
 are you going to love 2.1
Radiance
						Yes, i thing soradiance wrote:jesus !face wrote:Relative simple...radiance wrote:very cool.
Radiance
Radiance
But, switch to next frame, generate the mesh from the ICE pointcloud, export and saving is just on click in Softimage.
Alltogether also 4 single and one double click per frame
I code in c++ with the Softimage SDK, i think, it would be not the problem. But only under Windows...radiance wrote:are you able to create some sort of batch OBJ exporter script in softimage that also exports camera position etc as command flags ?
Radiance
Where have You been all the time
You got xsi 7.0 or 2010??
i7 2600K + 2X gtx 580 + GTX 560 Ti + 8gbram + Win7 +
AUTODESK SOFTIMAGE 2012
www.behance.net/mlody47
Time is relativemlody47 wrote:Where have You been all the time
Scaling and sizing is not very complex. When you have access to the parameters, you must only multiplicate it with the vectors.
Max 10 lines of code...
I have 2011
For 7.x there are a plugin with the name mt_static_instancer from Helge Mathee, an earlyer software engineer from Softimage.
Another plugin, similar to mt_static_instancer. Work with 2010.
http://vimeo.com/7218396
And little remark: ICE is not plugin for Softimage, it is a part of Softimage.
Yes, youre right.Kroma wrote:Another plugin, similar to mt_static_instancer. Work with 2010.
I have seen that, but i haven´t know that it works with ICE...
