ICE
radiance
very cool.
how are you retrieving your images ? are you manually saving and closing octane per frame ?
Radiance
face
radiance wrote:very cool.
Radiance
Relative simple...
I export the obj, playing with settings and save the ocs. Because, if Octane crashed, i have a backup.
Render, save image, export new obj with the same name, reload it in Octan, render again...
http://vimeo.com/user2509578
radiance
Radiance
Relative simple...
jesus ! :shock:
are you going to love 2.1 ;)
Radiance
face
Radiance
Relative simple...
jesus ! :shock:
Radiance
Yes, i thing so ;)
But, switch to next frame, generate the mesh from the ICE pointcloud, export and saving is just on click in Softimage.
Alltogether also 4 single and one double click per frame ;)
radiance
are you able to create some sort of batch OBJ exporter script in softimage that also exports camera position etc as command flags ?
Radiance
face
radiance wrote:are you able to create some sort of batch OBJ exporter script in softimage that also exports camera position etc as command flags ?
Radiance
I code in c++ with the Softimage SDK, i think, it would be not the problem. But only under Windows...
mlody47
Where have You been all the time :)
You got xsi 7.0 or 2010??
i7 2600K + 2X gtx 580 + GTX 560 Ti + 8gbram + Win7 +
AUTODESK SOFTIMAGE 2012
www.behance.net/mlody47
face
mlody47 wrote:Where have You been all the time :)
Time is relative ;)
Scaling and sizing is not very complex. When you have access to the parameters, you must only multiplicate it with the vectors.
Max 10 lines of code...
I have 2011 ;)
For 7.x there are a plugin with the name mt_static_instancer from Helge Mathee, an earlyer software engineer from Softimage.
Kroma
Another plugin, similar to mt_static_instancer. Work with 2010.
http://vimeo.com/7218396
And little remark: ICE is not plugin for Softimage, it is a part of Softimage. ;)
face
Kroma wrote:Another plugin, similar to mt_static_instancer. Work with 2010.
Yes, youre right.
I have seen that, but i haven´t know that it works with ICE...
Return to “Works In Progress”
