Can you post the .obj file which makes Octane crashing at your place?
I will try if it will crash here too with it!
Are you running Octane with admin rights?
Best Regards
Melese
Octane crashes during importing obj file
- meleseDESIGN
- Contact:
XP 64-bit | ASUS MARS DUAL GTX285 4GB Limited Edition | DUAL XEON X5570 | 48GB DDR3 ECC Reg 1333MHz
Hi,meleseDESIGN wrote:Can you post the .obj file which makes Octane crashing at your place?
Best Regards
Melese
I used a file from:
Best Regards,radiance wrote:can you try with an obj and mtl file that we know works first ?
like the benchmark scene here: http://www.refractivesoftware.com/forum ... f=21&t=996
Radiance
neoone
Win XP 64 Sp2 | Geforce 9600 GT 512 MB | Quad 2.66GHz | 8GB
- meleseDESIGN
- Contact:
In your signature is writen that you're using Win XP 64-bit SP2 and you have also Windows 7 Ultimate?
Sounds a bit confusing to me, because here everything works great with XP 64-bit SP2, 196.21 display driver and cuda 3.0.1 driver.
Maybe you will need to install the "Visual C++ 2008 Redistributable Package" to get it runing correctly. Have you installed it?
Melese
Melese
that should not be needed anymore with beta2.meleseDESIGN wrote:In your signature is writen that you're using Win XP 64-bit SP2 and you have also Windows 7 Ultimate?
Melese
it's built in a new way that does'nt require the redistributables...
Radiance
I use 2 different hard drives, so after problems with xp64 i've installed windows 7 ultimate on the socend one to know if it is a os problem.meleseDESIGN wrote:In your signature is writen that you're using Win XP 64-bit SP2 and you have also Windows 7 Ultimate?
Melese
I used different driver version, not only the latest.
Best Regards,
neoone
I kinda doubt you have to go that farneoone wrote:Hi,radiance wrote:have you tried the registry tdrlevel setting here: http://www.refractivesoftware.com/forum ... ?f=9&t=824
if that does'nt help, we're out of options.
either you're card is damaged or your OS installation is damaged...
Radiance
So i've tried use GTX 275 with 1796mb, reinstalled all programs... and octane crashes.
Then i'v install windows 7 ultimate with my old 9600 GT.... and octane crashes.
Trully I've no idea what to do. Maybe have to wait until final version will be finished.
Best Regards
Windows 7 x64 | Blender | Core2 Quad Q6600 | 8GB | GeForce 9600 GT
Hellow all,
Im having the same problem but in my case the (((---GPU_Benchmark_v0.1_Octane_v1.02b2---))) file works perfect in all versions of octane. So, I think its not a problem of my GPU
BUT, when I try to import my own OBJ (exported by 3dsmax) octane crashes during importing.
What Im doing wrong?
Can someone help me pleaseeee???
_________________
Windows 7 64bits
gtx580 - driver 266.58
12gb RAM
_________________
Windows 7 64bits
12gb RAM
