My new GTX 470 is showing up as a GTX 465
t_3
chrisskinner78 wrote:Yeah thinking about it space might still be a bit tight. I've got a Cosmos Cooler Master, the power supply at the bottom is quite close to the spare slot.
that should be fine from a thermal viewpoint, as the card is surely deeper than the psu. also the psu won't imo get that hot in a bottom config. the only thing is, that the 3rd pcie slot needs to be the 2nd last on the board (if standard atx size), otherwise it may not fit...
The obvious is that which is never seen until someone expresses it simply
chrisskinner78
Ah right, thanks for all the advice t_3!
http://www.skinnercreative.co.uk
i7-950 / 12GB SAMSUNG DDR3 / GTX470 / Win7 64 Pro
t_3
chrisskinner78 wrote:Ah right, thanks for all the advice t_3!
glad to help - hope you make it to a double-power setup :D
chrisskinner78
Thinking it might be a 570 at the moment, think nvidia are phasing out the gtx 470 because it was bit of a flop and there aren't actually that many around, all the £200 470's seem to be sold out.
I'll let you know how I get on. You never know my avatar might be smiling next time you see it...
