that should be fine from a thermal viewpoint, as the card is surely deeper than the psu. also the psu won't imo get that hot in a bottom config. the only thing is, that the 3rd pcie slot needs to be the 2nd last on the board (if standard atx size), otherwise it may not fit...chrisskinner78 wrote:Yeah thinking about it space might still be a bit tight. I've got a Cosmos Cooler Master, the power supply at the bottom is quite close to the spare slot.
My new GTX 470 is showing up as a GTX 465
„The obvious is that which is never seen until someone expresses it simply ‟
- chrisskinner78
- Contact:
Ah right, thanks for all the advice t_3!
glad to help - hope you make it to a double-power setupchrisskinner78 wrote:Ah right, thanks for all the advice t_3!
- chrisskinner78
- Contact:
Thinking it might be a 570 at the moment, think nvidia are phasing out the gtx 470 because it was bit of a flop and there aren't actually that many around, all the £200 470's seem to be sold out.
I'll let you know how I get on. You never know my avatar might be smiling next time you see it...
