SSS and human skin
matej
The transmission param of diffuse shader is "hidden" by default (hollow circle). You can only access it in the graph editor, by manually connecting the texture node to it.
cgmo.net
boeing727223
Thanks! I think I'm slowly getting it.... I did find the transmission node on the diffuse material and here is what I did. I created a float texture (using a spec map) connected to the transmission node on the diffuse material. Just for laughs I also connected a scattering medium to the medium node on the diffuse material. These all got connected to a mix material and the other side of the mix is my glossy material with diffuse map, spec, and bump maps. The mix setting of 0 is all white, and as you up the setting it gets more like skin. I still can't figure out how to get the transmission param in the graph editor via the diffuse material.....it never shows up in node inspector...
boeing727223
Something is happening..... here is a quick render
http://boeing727223.deviantart.com/#/d4h4057
