LiveDB not loading Textures..Max 2010
justix
Hi, I'm trying to load a Material through the LiveDB but no texturs get loaded different from the standalone..
+1 for region render (both 3dsMax and standalone)
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
Karba
justix wrote:Hi, I'm trying to load a Material through the LiveDB but no texturs get loaded different from the standalone..
Hi
Just checked under 2010. Everything works fine. What is your problem exactly?
justix
Hi
For unknown reason despite having set the path for the textures to be imported I had to restart the renderViewport in order to get them on screen...
Thinking to migrate to 2011 in order to import directly from Rhino..should I deactivate the plugin first?
Thank you
Karba
Hi
Thank you
Probably not. I have 4 3dsmax versions with octane plugin on one computer. All plugins work with the same licence.
Return to “Autodesk 3Ds Max”
