Ooh. Thaaat. Right. The first letter looked like a C to me, that's why I couldn't find any mention of it. I thought Refractive was going to launch another madly innovative piece of software.Sam wrote:I told you it was just in front of you... from a long timeI still can't find it. Ah well. I guess I'll learn in due time. What am I doing skimming software forums on my holiday anyway?![]()
http://www.refractivesoftware.com/forum ... 97&start=0
Octane Render Commercial v1.02 beta2 Released
- MadMinstrel
Win 7 x64 | Geforce GTX295 | Quad 2.4GHz | 4GB
- EricDesign
- Contact:
is ok nowradiance wrote:Hi,
there is a limit:
64 'image' textures maximum.
32 'floatimage' textures maximum.
these are cuda limits that i haven't managed to develop a workaround for.
try to be a bit sparingly with floatimages, try to join some objects and maps if possible into larger ones.
Radiance
but i post my solution if order people have the same problem ,
i have two monitor and is ok but if you use utramond is crash Octane, so just close ultramond and all work fine
so octane and ultramond = low quality or crash
thx.
Hey radiance, at first, Thanks for the nice version of octane, but i have an problem.
Octane crash to desktop, if i set the resolution to 4000x4000px. My desktop resolution ist 1680x1050px.
The drivers of my sytem are the newest, cuda 3.0 is installed.
|Q8400, gtx770 4Gb |12 Gb Ram|Win7 64 Bit|C4D R15 Visualize and Octane
my 3D-Blog: http://katerlake.blogspot.com
my Vimeo: http://vimeo.com/user4046032
my FlickR: http://www.flickr.com/photos/45536398@N05/
maybe you don't have enough video ram ?katerlake wrote:Hey radiance, at first, Thanks for the nice version of octane, but i have an problem.
have you tried going a bit lower say 3000x3000 ?
Radiance
Its also possible that you have the default GPU timeout delay
If you got a message saying that your display driver recovered
http://Kuto.ch - Samuel Zeller - Freelance 3D Generalist and Graphic designer from Switzerland
Yes, the problem is bey every resoltution bigger than the resolution of my desktop. I´ve testing with 2560*1920px and i use 150mb of 1024 videoram then crash octane to desktop.radiance wrote:maybe you don't have enough video ram ?katerlake wrote:Hey radiance, at first, Thanks for the nice version of octane, but i have an problem.
Radiance
But if i change the resolution before i add an mesh, the octane render it.
If i add an mesh and delete the note. The Mesh is always in the render viewport. And i f change my resolution, octane crash every time.
I noticed that if I load a 16bit grayscale .tif image in the opacity channel it immediately crashes Octane whether loaded as "image" or "floatimage". 8bit image loads fine so far. Is this a known limitation?
Rod
Asus P6T Deluxe V2
Intel core i7 920 (2.66 GHz quadcore)
12 gig RAM Kingston HyperX
BFG GTX 285 OCX
CPU cooling - Noctua NH-U12P SE2
OCZ Vertex Turbo 120 GB Sata II SSD
Windows 7 Ultimate 64bit
Asus P6T Deluxe V2
BFG GTX 285 OCX
katerlake wrote:Yes, the problem is bey every resoltution bigger than the resolution of my desktop. I´ve testing with 2560*1920px and i use 150mb of 1024 videoram then crash octane to desktop.radiance wrote:maybe you don't have enough video ram ?katerlake wrote:Hey radiance, at first, Thanks for the nice version of octane, but i have an problem.
Radiance
the issue here is the video driver watchdog timeout which is very low on windows 7.
try the registry fix here: http://www.refractivesoftware.com/forum ... stry#p8019
Radiance
- gpu-renderer
Does the bump mapping work on the latest.. what format should the image be in! Any pointers and bump map images would be welcomed... so far few of mine work... something aint right with octane bump mapping... thanks
i7 920 2.66ghz quad core, gtx 285, asus p6t, 6gb OCZ 1600mhz ram, Windows 7 64bit ultimate. Nvidia cuda Driver v3 Nvidia display drivers V193.13. Octane beta 2
