Exposure to HDRI
adriano.ol
Is there any way to implement saving a range of different exposures at once, so they can be merged into HDRI imagem in Photoshop, for instance?
It would be very usefull for animation.
Karba
adriano.ol wrote:Is there any way to implement saving a range of different exposures at once, so they can be merged into HDRI imagem in Photoshop, for instance?
You can use Octane Camera and make regular animation of exposure parameter.
If you want just to get final hdri from several images with different exposure, you can save render image to exr format. You have to swich off "applay tone mapping for output" option first.
adriano.ol
Thank you.
acc24ex
Hey Karba, this is excellent info, thanks, I wasnt sure what workflow to use with hdri..
Can you give like an automatic +2 +1 0 -1 -2 exposure and save all in .exr with one click .. that could give new users ability to produce better renders and make it quick to use
like you get it on newer DSLR cameras, seems simple enough of an idea, would be this be easy to implement_?
Karba
What do you need it for?
Return to “Autodesk 3Ds Max”
