Beta 2.2 RC1: Maya exporter plugin (unofficial)
Moderator: JimStar
tchoa
Maya's camera should be exported correctly.
(for correct matching you should set its 'Fit Resolution Gate' to 'Horizontal')
Your issue is certainly caused by a scale problem.
Check if you've the latest version of the script that's not handling the scale.
(if I remember well Bazuka removed the rescale things in the script)
And set the 'Obj File Unit' in the octane 'OBJ Mesh Import'...
Win XP x64 | Q6600 2.40GHz | 8Go | GTX470 1.28Go // Win 7 x64 | I7 Q740 1.73Ghz | 6Go | GTX460m 1.5Go
MTECH
I know there hasn't been a new version of this exporter in awhile, and for the most part the current one works pretty well.
One feature missing that would be useful to a lot of people would be the option to select .exr and .png 16-bit file types for animation sequences. I believe some of the other exporters have this now, and it would be great to have that in the Maya one! If I had any programming skill I would gladly do it myself, but unfortunately I don't :(
Core i7 920 | 12 GB RAM | Nvidia GTX 470 & 260 | Win Vista x64 | Maya 2012.5 x64 | Octane beta2.57
PolderAnimation
Meathead wrote:Does not work with Maya 2013 :( dam!
is this problem solved? of is the octane maya plugin still not available of maya 2013?
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
MTECH
It seems to be working alright for me. Make sure you have the latest version of the plugin? 2.5 I believe. (granted there hasn't been a new version for a long time)
mainframefx
I got a little in to MEL script and added an option that I was missing.
You can now choose the output format when rendering an animation. All possible formats (PNG, PNG 16bit, EXR and EXR Tonemapped) are available.
Download:
octane2maya_test_script_2_5_1.zip
(7 KiB) Downloaded 335 times
Cheers
i7-3930K@4,8GHz | 64GB RAM | 2x GTX 560 Ti 448 | Windows 7 x64 SP1
i7-3930K@4,2GHz | 32GB RAM | 1x GTX 560 Ti 448 | Windows 7 x64 SP1
i7-2600K@4,4GHz | 16GB RAM | 1x GTX 560 Ti 448| 1x Quadro 2000D | Windows 7 x64 SP1
videoprice
mainframefx wrote:I got a little in to MEL script and added an option that I was missing.
I haven't tested it very much. Please report any bugs if you encounter one.
Download:
Cheers
Paul, thank you very much for your job. Finally!!! Your script work perfect!!! Thanks again:)
MTECH
Wow, thanks for doing this! Outputting EXR's will go a long way in post production.
mainframefx
You're welcome guys, thanks for testing it :)
ruhi
First of all.. i really appreciate your job.
There is little problem we have..
if i want to use camera only option. Octane imports many unwanted copy of obj files. and this error causes very big time losses in big scenes.. (double voxelizing, parsing faces etc.)
if i unmark the checkbox of camera only option.. There is no problem..
i hope you response quickly..
cheers..
Hatak
If it unoffical exporter, where is official ? :lol:
My english is bad. Sorry D:
Dual Core E6700 3.2Ghz | GTX 580 | 4gb ram | Win7 64 |
Return to “Autodesk Maya”
