I have some questions about the plugin for 3dsmax!
- marilu2011
Hi, I'm interested in buying the license of the plugin for 3dsmax, but I'm sure it is the following: using the Octane directly in 3dsmax I'll be able to render animations without having to open the program Octane every frame, as with the exporter, or it renders and saves the same time as with the rendering of 3dsmax? need of explanation before I had the plugin.
Hi Marilu,
Yes, the 3DsMax plugin is fully integrated, there is an additional window that is the octane render output that responds in real time to your changes in 3DsMax. When you render animations, it does not open up the octane.exe every frame, it will render each frame in the octane render window that is attached to 3DsMax.
Cheers
Chris.
Cheers
Chris.
